Old 8th July 2010, 04:14 PM
Eternal Eternal is offline
Default welding time?
Hay people so far im at this stage....
It says to tack D1-D6 in but these will go over the top of some tacks that have not been welded yet. Should i fully weld what i got so far or should i just weld the bits i know will be covered? then continue with the dif/suspension work. Also as it says i need to move the chassis forward but if i moved it 40cm forward alot of the chassis would be hanging off the table and i dont feel happy doing that as its tacked lol
Skyline Roadster
Old 8th July 2010, 05:14 PM
If it's been tacked properly it will be alright. Try pulling on the pieces you are doubtful about. If any come away, do them again
Old 8th July 2010, 05:51 PM
ahh just been reading into the book a bit i dont have any of the CP plates yet as i just ordered them. Would it cause trouble if i do the tunnel first? Did a load of checking and i can use the MT75 tunnel with the skyline gearbox happy days!
Anyone know what this is and do i need it? lol
Skyline Roadster
Old 8th July 2010, 07:11 PM
Looks like a VSS. All depends on what the ECU does with it.
Old 8th July 2010, 07:14 PM
im using the auto ecu you just bridge 2 pins and its all good. there was no connection like that on the old box. have not found any info on it at all lol ohh could it be a rmp sender? or speed sender.
Edit: it was a kph to mph converter. removed now and all is good.
So yeah guys if i build the tunnel i guess i can then weld it all up then move it forward build the back end then flip it upside down and weld the underside?
Skyline Roadster
Old 8th July 2010, 07:36 PM
The sierra 4x4 has the VSS on the front transfer shaft on the oposite side to the diff.
I Imagine your ECU will be OK without it, the main problem we see on ford converted cars with VSS disconnected is stalling of the engine when comming to a halt.
