Old 15th July 2010, 02:27 PM
Johnnybizzle Johnnybizzle is offline
Default IVA Application
Hi Guys,
Just filing out my application form, got stuck at a couple of points looking for advise.
Maximum design speed - should i put 110mph which ive been told it will do or 70 in theory i wont be goin any faster?
Design weights-
Axle 1
Axle 2
Axle 3
Gross
Train
Towable Mass
Spec. is honda cbr1000 roadster, roll cage, 2mm box section frame, sierra running gear, ali panels
i was thinking about 600kgs gross weight plus driver, how does this split into axle weights?
any help would be appriceated
regards Jon
Old 15th July 2010, 05:38 PM
you only need axle 1 and 2 plus gross.
Like adrian i did 450kg 450kg and 900kg. my max speed i put at 118 if it doesnt sound realistic then they wont like it.
My Pictures
Old 15th July 2010, 09:13 PM
thanks guy, wanting to get paper work off this weekend, another question... do i send all my photos of the build as evidence with application or take on the day??
After the IVA do i go and see the nice people at DVLA with the cert and let them sort out registration and DVLA inspection (what does that entale?)
regards Jon
Old 15th July 2010, 10:48 PM
keep the pictures for the day. you will also need the pictures and receipts for the dvla to hand over the counter with the registration froms
My Pictures
