Old 14th July 2010, 07:06 PM
Davey's Avatar
Davey Davey is offline
Sorry Dan, my day went a bit tits up towards the end of afternoon so I didn't get chance to examine my LSD. I'm still not convinced this is LSD though so if you really want a LSD I'd give it a body swerve unless you can get definite confirmation of the diff's status.
D.
Old 16th July 2010, 06:15 PM
snapper snapper is offline
Light surface rust should be no problem.
Turning 1 output on an LSD should turn the other the same way
Old 17th July 2010, 09:41 PM
dan_g8 dan_g8 is offline
thanks for the replys, ive decided not to go with this diff now, mainly because of big verns comment about all of the viscous drives failing, dont think that this diff will be up to the job!
Old 18th July 2010, 09:36 AM
Big Vern Big Vern is offline
Dan,
My LSD's were only failing due to dumping the clutch with high revs and 1.6 Bar boost (aprox 300hp)
BV.
Old 18th July 2010, 07:53 PM
bv, the engine that i am using is a v8 so there will be a hell of alot of torque going into the diff and i have plans to tune the engine aswell so i dont think it will be worth the risk.
Just picked up an 3.6 open diff which will do for now, will take me up to iva after ill either go for a "propper" lsd or an electronic diff locker.
Dan
Old 19th July 2010, 05:35 PM
Davey's Avatar
Hi Dan, I whipped the rear cover off my diff which is definitely LSD and it looks much like your one only without the rusty bits . I did take a photo on my phone but I've gone and left the PC-phone lead at work dozy bugger ain't I?
D.
