Old 22nd July 2010, 07:47 PM
The seller has 1 set of followers left at that price if any one else with a CVH might need them.
My car will be on the road within my original budget
as these parts are such a good price it means I can still get my new tyres
Old 22nd July 2010, 11:10 PM
Buking Fargin
http://cgi.ebay.co.uk/ford-1-8-cvh-r...#ht_1801wt_911
Old 30th July 2010, 04:33 PM
SUCCESS
My new cam followers arrived yesterday, so had a good read of the manual last night to get my head around the fitting process, this afternoon I set to on the engine.
Now, I openly admit I am not a trained mechanic, more a case of learnt a little over the years when repairing various cars I,ve owned due to keeping the costs down on basic repairs etc......
Anyways......off with the bonnet & socket in hand off came the rocker cover, with the manual beside me I undo the first set of rocker arms ( keeping them in the correct order on a cardboard cutout to ensure they went back in original place etc).
In the manual it states that the tiny oil passage hole in the follower MUST go opposite to the oil passage hole in the cylinder head, so I pull out the first cam follower to find this was incorrectly fitted
I finally fit all the new followers ensuring they are fitted correctly ( each new one has a painted mark on them to aid fitment ).
It is obvious that my engine has had replacement followers in the past as I found that 5 out of the 8 were incorrectly fitted.
I bolted everything back to the correct torque settings, turned the fuel on ( I have an inline fuel tap ) & started her up......... she started first time & I can,t tell you how chuffed I am she,s running like a purring cat.
I also set to & sorted the high tickover problem I had, with thanks to the spare carb I have I sussed out that as I,m not running the automatic choke system the "step" rotor that is adjusted when using the auto choke was set at its highest tickover position, a quick fiddle with to allow it to rest as if the choke had warmed the engine & now she,s ticking over at the correct revs
Thanks for everyones suggestions of what the prob was, I,m now a very happy bunny indeed.
Old 30th July 2010, 06:49 PM
David_17's Avatar
David_17 David_17 is offline
Nice to hear you've got it sorted What's next on the list??
*updated 7/6/11*
Old 30th July 2010, 06:56 PM
Cheers Dave,
next on the list is the "bleeding brakes" ......... I mean ...brake fluid going into the system, then once I have brakes that will stop me.....time for a little drive....on a private road of course
Old 30th July 2010, 07:04 PM
David_17's Avatar
awesome
*updated 7/6/11*
Old 6th August 2010, 07:53 PM
antonia800 antonia800 is offline
its all to do with the oil you must use a mineral oil in the cvh 10/40 dont be tempted by performance oil, duckhams do a good one (from my time racing a XR2) came of track ratteling like a bag of spanners changed the oil quiet as a mouse brilliant
Old 6th August 2010, 07:59 PM
It was a strange situation..last year when I bought the donor car, I drove it home approx 200 miles, ran great, nice and quiet... stripped the donor for this build, so the engine has been idle for about 13 months.
The noise was traced to the cam followers, I,ve replaced all 8 & its super quiet now
I,ve put fresh oil & filter in so hopefully with all that it should be a happy motor.... I must admit, I don,t intend keeping the engine very long got a transplant in mind during winter .
ps... I used to race motorbikes... crazy days
