![]() Its only a small lip that sits on the chassis inside the nose but there is still room for a couple of m6 bolts on each side rivnutted into the chassis, i cut some big washers almost in half and used these to spread the load a little, i also put another 3 underneath the bottom at the front, again with big washers on them.
![]() Hi Terry,
I had the same problem. Not enough on mine for a bolt one side so had to adapt and overcome as they say. I'll email you some photos. http://i641.photobucket.com/albums/u...y/DSCN3877.jpg http://i641.photobucket.com/albums/u...y/DSCN3878.jpg Couldn't email, too big so here is some links - hopefully of some help. Last edited by DaddyA : 29th July 2010 at 08:27 PM. Reason: Insert photo links |
![]() Thanks Daz,
Those pictures are just what i needed ![]() Terry |
![]() I used m5's on mine with speaker washes top and bottom
My Roadster Is Finished NerNer....... Pigs can fly, you just have to carry them onto the plane. My Pictures http://s707.photobucket.com/user/ashgardiner/profile/ |
![]() I'm afraid the mold for the nose cone doesn't allow for much a flange to be formed for fixing of the nose cone. Going to have a go at modifying the mold soon to allow for better fixing.
It does fix on okay at the moment, if not a little awkward. Regards.....AndyH
![]() Fix it at the bottom then use a dzeus fastner where it meets the bonnet so it holds both the nose cone and the bonnet......simples!
![]() Andy, adding a bit to the flange is easy done if you feel the need..clamp some wood to the flange while it's off the nose with enough to give a bigger flange then simply gel and 'glass it ....resulting in a wider flange ![]() Any news on the single seater beastie? I made me own but the engine may be a problem oh and will fry the IVA bods brains... ![]() |
![]() Kayak's is looking good Mark, that is the plan with the nose - some pvc trim
Single seater is done to Mark, Chris has trial fitted it and reports that all is hunky dorey... AndyH
Haynes Roadster / Saturn GRP Bodywork. Now available direct through http://www.gillhamonline.co.uk/ or contact me direct on andrew.hugill@ntlworld.com Regards..........AndyH Last edited by spud69 : 30th July 2010 at 03:31 PM. |
