Old 30th July 2010, 08:01 AM
I used m5's on mine with speaker washes top and bottom
My Pictures
Old 30th July 2010, 09:09 AM
I'm afraid the mold for the nose cone doesn't allow for much a flange to be formed for fixing of the nose cone. Going to have a go at modifying the mold soon to allow for better fixing.
It does fix on okay at the moment, if not a little awkward.
Regards.....AndyH
Old 30th July 2010, 02:33 PM
fabbyglass
Fix it at the bottom then use a dzeus fastner where it meets the bonnet so it holds both the nose cone and the bonnet......simples!
Andy, adding a bit to the flange is easy done if you feel the need..clamp some wood to the flange while it's off the nose with enough to give a bigger flange then simply gel and 'glass it ....resulting in a wider flange
Any news on the single seater beastie? I made me own but the engine may be a problem oh and will fry the IVA bods brains...
File Type: jpg 1st composite kayak out of the mould.JPG (29.7 KB, 120 views)
Old 30th July 2010, 03:24 PM
Kayak's is looking good Mark, that is the plan with the nose - some pvc trim
Single seater is done to Mark, Chris has trial fitted it and reports that all is hunky dorey...
AndyH
Old 30th July 2010, 03:56 PM
fabbyglass
Cool when can I see a picture of the beastie?
Old 30th July 2010, 04:05 PM
Hopefully after Chris had got back from his hols we can tease some pics out of him....
Old 8th February 2011, 10:48 AM
stephanedu14 stephanedu14 is offline
Hello has all.
After a small research j' found this post.
Is this step a little be likely to bore in the tubes, especially in the periphery of the nose gear.
Why not to put a small square l' has; interior and to make a grip with a strip d' alluminium in order to tighten the nose
