Old 7th August 2010, 07:28 PM
layotn20 layotn20 is offline
just took the back casing off the diff and on the crown wheel is stamped from ford( 83bg-4210-sd) also it does have 3.62 stamped on it. so i take it, its a 3.62? if so what shud this top out mph. and it seems very clonky going into gears is this with all kit cars or do you reckon the diff could do with a refurb
cheers jim
Old 8th August 2010, 08:01 AM
snapper snapper is offline
Top speed will be about 110 but you will get ther quickly.
Clonky gear change is a bike engine/ box standard as the dogs engage, bike boxes can go up the box without dipping the clutch
Old 8th August 2010, 08:22 AM
Why take of the back cover?
Lock one output. Put a pointer on the input.
Turn the output 1 revolution and count the turns + degrees on the input.
By My Calcs.
3.33 = 3 rotations + 118d
3.62 = 3 rotations + 223d
3.92 = 3 rotations + 331d
So it should be fairly obvious at ~106d seperations.
Old 8th August 2010, 11:15 PM
Wouldn't it be half of that due to the differential? In my understanding you either have to rotate both outputs 1 rev each, or lock one output and rotate the other one two times.
(Oh, by the way, here is a classic film about the pripciple of a differential, great if you need to explain it to somebody: http://www.youtube.com/watch?v=K4JhruinbWc . Skip to 2:00 if in a hurry)
Old 9th August 2010, 07:22 AM
I understand what you mean, you can leave one wheel on the ground or lightly apply the handbrake to prevent rotation of the free wheel.
This is not a problem with an LSD but can be an issue with the Quaife ATB
