Old 8th August 2010, 12:12 AM
Thanks David, that's a very clear diagram. And quite usable as a PDF on those 4 pages, too!
Old 9th August 2010, 08:52 AM
Nice work David
I am sure that layout will be very usefull in the not too distant future
The PDF works a treat, I look forward to the completed design
Old 9th August 2010, 08:58 AM
David,
Just looking at the diagram. Very useful as I to am going to be making my own wiring loom.
One thing I did notice is that you don't have a fuse in the permenant feed for the hazard lights. I think in the original Sierra loom there is a 10a fuse in this feed.
Old 9th August 2010, 09:44 AM
snapper snapper is offline
Megajolt has 7.5 amp fuse also check Edis, this should be on a separate fuse.
If the Megajolt fuses or fails the Edis will provide 10 degs advance for limp home
Old 9th August 2010, 12:05 PM
davidimurray's Avatar
Thanks for the further feedback everyone. Wil try and update the drawings soon - I been busy on the car over the weekend and will be tonight so will squeeze in some time soon.
Davedew - must admit I hadn't thought about fusing the Hazards. I think I could simply do this taking a branch off the Horn/fan.
Snapper - as I'm using a hard rev limiter with the Megajolt, the coil power is controlled by the megajolt itself. Hence I figured that if the fuse was to blow to the megajolt, then you would also lose the coil power and you couldn't use the limp home feature of the EDIS module - hence the single big fuse - whether this is the correct assumption - I'm not sure !!??
Old 9th August 2010, 04:29 PM
Default New Version V1.1
Hello
Here we go - the latest version (V1.1) of the diagram for comment
Modifcations are -
Inclusion of 200A master fuse
Added dedicated alternator supply
Added hazards to fused supply for horn/rad fan
Corrected handbrake/brake fluid light to correct neg switched circuit
Again guys, all comments and feedback gratefully received.
Old 9th August 2010, 04:35 PM
David,
Your going to shoot me.
Just been looking through the IVA manual at the parking light section. I think that you need to swap your ignition switched supply for the sidelights to a permenant supply to comply with the regs.
Old 9th August 2010, 10:47 PM
Nah - that's far to kind
Seriously though it's great to have lots of input and feedback from people - better now than in the middle of the IVA test.
On the parking lamp subject (section 30 IVA manual) - I read it as they are optional on vehicles below 6m long and 2m wide, which the roadster is. If you do have parking lamps, then you must be able to turn them on without the key in.
That would suggest we don't need them. What does everyone else think?
Old 10th August 2010, 08:08 AM
Just looked at it again. The table seems to indicate like you say that they are optional on vehicles under 6m long.
Ignore me then. I wont mind, the wife does it regularly!!
Old 10th August 2010, 08:25 AM
6M... I thought Class M was just for cars,
I think the longest UK production car was the AM Lagonda at about 17'4" (6M being 20' ! ) well it was when it ceased production in 1990.
