Old 6th August 2010, 08:57 AM
mark mark is offline
Originally Posted by Jeze2903 View Post
Hi Andy, Ive looped the heater hose from the auto choke to the tee with the bottom hose connection on the L/H side of the engine, if that makes sense. The water flows through this pipe fine, but not through the rad
Have you checked that your therostat opens?
Have you checked for airlocks?
Old 9th August 2010, 11:32 AM
Jeze2903's Avatar
Jeze2903 Jeze2903 is offline
Hi Mark, I have considered the Thermostat, and plan to check it out this week. Cheers
Old 9th August 2010, 05:49 PM
oops
I,ve taken some photos but forgot to post them on here
I,ve just got home & about to have dinner, I,ll post the pics up this evening.
Old 10th August 2010, 09:30 PM
sorry for the delay in posting these pics, had a prob with my camera
first pic shows the expansion bottle location & the hoses from the water pump exit
2nd pic shows the bottom hose route
3rd pic shows the top hose from the thermostat housing
I hope the pics help, this I,m sure isn,t the only way to route the hoses , but how I did mine
Please excuse the various wires in the photos, I was doing some wiring when I took the pics.
Old 10th August 2010, 10:41 PM
Ah, what I thought was where the thermostat would go on my Polo Rad, is actually where the fan temperature switch goes Got to love the internet.
Sean
Old 10th August 2010, 10:43 PM
thats where I was getting confused with your request for a pic , sorry for "not getting it"
Glad you got it sorted
Old 14th August 2010, 03:30 PM
Jeze2903's Avatar
Hi Andy, Thanks for the pics. I have done my top hose pretty much the same, but have tee'd in the pipe that should go to the expansion tank. Where you have placed the tank looks much better. Am I correct in thinking the outlet from the expansion tank joins the Tee that connects to the engine block and auto choke? Your bottom hose route appears similar to mine, but where does the other end of the pipework go, I cant see in the pics. Does it connect to the steel pipe leading into the engine block?
Thanks again for this, off out now to re mount my expansion tank
Old 15th August 2010, 11:18 AM
no prob, glad the pics help.
The bottom outlet of the expansion tank is connected to the "T" piece that is then connected to the water pump elbow on the passenger side of engine, the top "overflow" point at the expansion tank is connected to the auto choke/thermostat housing.
I,ll get some more clearer pics today & post them up.
Old 15th August 2010, 02:37 PM
Jeze2903's Avatar
Hi, cheers Andy. Ive got the expansion tank thing clear now, just curious the path the lower radiator hose takes. Im thinking it connects to the water pump pipe?
I'll post a couple of pics later of my current set up that doesnt work!
Old 15th August 2010, 08:39 PM
Jeze2903's Avatar
Pics of hose route to bottom of radiator. Water won't pass through the long horizontal pipe..could it be an air lock causing this?
http://www.flickr.com/photos/jeze1967/4894329977/
http://www.flickr.com/photos/jeze1967/4894329257/
http://www.flickr.com/photos/jeze1967/4894924038/
