![]() Hmmm, the senders I have don,t have an earth, the gauges have an earth & in the instructions it says " Direct to engine ground" from a terminal on the back of the gauge, which I have done
![]() Now you can see why I had an auto electrician wire up the major part of my cars wiring ![]() Tho, I had success yesterday....successfully wired in the reverse light, fog light & the fuel level gauge...all working as should be ..... I can now tell how much fuel I have ....yeehaa ![]() cheers andy |
![]() Quote:
The block is your earth, so unless your ( t-pice, oil manifold, sandwich, whatever ) is an insulator then so long as your engine is earthed then the sender will be too. TT
![]() Quote:
I don,t think I have the sandwich plate the wrong way around, as if I had it positioned with the oil seal on the outside then I imagine oil would/could seep from the 2 mating surfaces ? is that correct? ![]() cheers for helping me out guys ![]() andy |
![]() the thread should make contact anyway.
Which guages are they? TT
![]() This is the type of gauges I,ve fitted
item number on the bay 380252463408 & the sandwich plate is this 380252487013 cheers andy |
![]() And you 100% have the preasure guage to the preasure sender and temp to the temp...
![]() nice price BTW
![]() Quote:
![]() ![]() Yes, the price is very good indeed, they do a full range of these gauges.. volts/oil temp/oil pressure/amps/water temp/boost etc, they look quite smart when lit up with an indigo blue colour , sandwich plate was ordered yesterday morning & was in my car before lunch time today, very good service ![]() cheers andy |
