  #33
Old 16th August 2010, 08:15 PM
Unhappy Join the club
In the same boat as you Davy, not been able to touch my build for the entire summer.
It sounds very much as if you have bought the same TIG welder as me.
I was a bit reluctant to go down the budget route but to be honest, I could not justify buying a high end set .... Not a hope in hell of finding a good quality, used single phase set in this neck of the woods.
Anyhow I was quite pleased with the TIG welder & it does what it says on the tin.
Here's a couple of test pieces that I done to try & get my eye back in .... Been over 20 years since I last TIG welded alloy
Here's hoping that your set will work as well as mine.
