Old 17th August 2010, 01:27 PM
carlknight1982's Avatar
Default Wing mounted side repeaters
DO you have to have these little side repeaters mounted in the wings?
Roadster No 2 build
Cost to Date : £93
Old 17th August 2010, 01:34 PM
mark mark is offline
You dont HAVE to, but in order to pass the visibilitly guidlines for iva its one of the best places for them
Alternatively you could mount them on the outer edge of your wing mirrors
Old 17th August 2010, 02:23 PM
The problem is carl that you have to be able to see them a 5deg angle from behind and the rear wing gets in the way if you're too low. If you can mount them high enough, on the scuttle or mirrors then that will be okay. They used to ignore it for 7 style cars but not anymore.
AndyH
Old 17th August 2010, 03:26 PM
mine are on the scuttle and passed iva on the scuttle. you just need to mount them high enough so they can be seen from behind the rear arches. Adrian unknowingly put his indicators in the side panels which is why he ended up having extra marker on the rear arches as he didn't want a hole in his side panel.
My Pictures
Old 17th August 2010, 03:30 PM
So a small pair in the nose cone and some like ash on the scuttle "should" eliminate the need for indicators in the wings
Roadster No 2 build
Cost to Date : £93
Old 17th August 2010, 07:10 PM
snapper snapper is offline
CBS do little button indicator repeaters that can be cut into the headlight bowls, looks neat and mr IVA likes them
