Old 21st August 2010, 11:02 PM
A fair bit of the running gear on the 4x4 Sierras is useable.
The front hubs will need replacing as they are not suitable for the Roadster & there will be some engine mods to do.
I am sure TT will let you know the full range of engines available on the 4x4 Sierra.
If a Limited Slip Diff floats your boat the 4x4 is not such a bad option
Old 22nd August 2010, 07:04 AM
2.0 DOHC
2.0 Cosworth
2.8 MFI
2.8 EFI ( Rare )
2.9 EFI
Only mod needed on the engien is a swap to a 2WD Sump unless you fancy welding the ALI.
Gearbox will be useless as it combines the transfer box.
Rear drive train is fine.
Front hubs can have the outer CV removed, so they may be useable but the geometry on the 4x4 is a little different to the 2WD so they still may not fit.
Old 22nd August 2010, 08:14 AM
gtipping gtipping is offline
Ok - options for the donor are increasing - another question (to increase possibility of donor at good price) -does the P100 pickup have the same running gear ?
Cheers for all the replies so far - appreciated guys.
Old 22nd August 2010, 08:38 AM
It has a solid rear axle so no independant diff or hub carriers, and the front uprights would be 5 stud. So only the engine and box are likly to be of use ( if it's petrol )
Old 24th August 2010, 10:28 AM
hey guys - there's no going back now - just picked up a 1.8 estate
Old 13th September 2010, 11:44 AM
xr4iwannabe xr4iwannabe is offline
Picking up on the sierra 4x4 thread. Has anyone ever done a 4x4 build, and what would it be like
Old 13th September 2010, 12:05 PM
There's been a couple of locosts.
I had thought about it but the transfer shaft on the gearbox would encroach badly into the drivers footwell. Fine if it's LHD mind.
Front geometry is a little different on the 4x4 too.
