Old 24th August 2010, 10:32 PM
I know you don,t really want to hear this, but .....
with it being 36mm & not 3.6mm out of line I personally would cut it out & replace to the correct dimensions, & if you do, then before you cut it out tack in a brace to avoid the chassis distorting.
Sorry, I don,t wish to sound like a "kill joy" but a 36mm error is alot.
Old 24th August 2010, 11:56 PM
nnrouty nnrouty is offline
ok thanks.
I have a mate who did all the tig welding. I will get him to come round again and see what he thinks.
Thanks for your thoughts, will let you all know how we get on.
Building 1800 Zetec Roadster
Old 25th August 2010, 12:09 AM
was everything cut to Book specification ? If so it should all go together..
If not you need to check every length an angle that has been laid.
Old 25th August 2010, 11:41 AM
Yea it was all cut to book spec which is why i couldn't understand why it had happened?
I am tempted to leave it and use alloy sheet to correct the problem when in comes to fitting the scuttle?
Old 25th August 2010, 12:29 PM
Sorry but you need to start off with a good square and flat chassis otherwise you're going to come across loads of problems later on and 36mm is an awful lot. If its only tacked then i would check your build table is marked out correct, HAndy may have some spare templates left, and remake it. Or you could bring it over to the North East and i'm sure me and HAndy could remedy the problem and jig on the suspension brackets so that you have a good base to start from.
All the Best....AndyH
Old 25th August 2010, 01:27 PM
The chassis is nearly complete. There is only one rail out of place and it is fully Tig welded in place. All other rails are fine.
Old 25th August 2010, 01:57 PM
36mm is well over a tube width. How on earth did you manage to do that?
Sean
