Sorry but you need to start off with a good square and flat chassis otherwise you're going to come across loads of problems later on and 36mm is an awful lot. If its only tacked then i would check your build table is marked out correct, HAndy may have some spare templates left, and remake it. Or you could bring it over to the North East and i'm sure me and HAndy could remedy the problem and jig on the suspension brackets so that you have a good base to start from.
All the Best....AndyH
The chassis is nearly complete. There is only one rail out of place and it is fully Tig welded in place. All other rails are fine.
Building 1800 Zetec Roadster Last edited by nnrouty : 25th August 2010 at 01:49 PM. |
36mm is well over a tube width. How on earth did you manage to do that?
Sean |
not sure. think i will go and measure again......
Building 1800 Zetec Roadster |
