Old 25th August 2010, 04:18 PM
In theory yes, but it will throw off most of the dimensions.
If you make the front wider, the suspension geometry will need looking at. You would also then need to make/have made custom bodywork, as nothing standard will fit.
McSorely did several versions of the 'LoCost' chassis, +4 width, +4 length etc. so whilst it is doable, it's a fair bit of work.
IIRC however, someone else on here (Dogwood maybe?) is building a wider version.
Sean
