Old 29th August 2010, 06:10 PM
Enoch Enoch is offline
Hi Ray, are you sure? Mine are definitely fixed, the cylinder is part of the casting that bolts to the upright - it can't move in relation to the upright. The anti lock valve came from a pre-abs Sierra. I think there are others out there that will do the job but I knew the Sierra one works and that it had 12mm threads in it so I went with that.
Enoch.
