Old 30th August 2010, 09:00 PM
David_17's Avatar
David_17 David_17 is offline
Default Handbrake cable
The way i've been going about my build is "if it looks wrong, it probably is". So guys, what have i done wrong with my handbrake cable?
Also, i plan on cutting it just before the handbrake lever, but what's best to join it back together?
*updated 7/6/11*
Old 30th August 2010, 10:20 PM
The adjuster goes behind the plate, so you adjust the cable from the diff area. If you cut the cable at the handbrake end, cable clamps can be used to rejoin the two halves.
Adrian
Old 30th August 2010, 10:24 PM
David_17's Avatar
Makes sense, thanks for the reply.
The reason i had it this way is the rubber grommets were already on the cable in that position (obviously more room in the sierra)
*updated 7/6/11*
Old 31st August 2010, 07:45 PM
Suggestion,and it has been made before. Set the cable up on one side brake and fit cable to other side and shorten only one side by pulling the excess out of one side.
Dont forget to remove any lip on the drums and this will make setting up the brakes easier after pressing the pedal to adjust them and then a few clicks manually they will be spot on.
Old 1st September 2010, 08:35 AM
locostkiwi locostkiwi is offline
hi guys not sure if it is me or if ive had a long day, but the above answer has me totaly confused
could someone please if possible take some pics for me in regards to how the handbrake system is set up at the rear.
cheers guys
Tony
Old 1st September 2010, 07:59 PM
David_17's Avatar
Basically he means instead of cutting a bit off each end, pull the slack through then just chop the one end.
I think instead of doing it that way, i'm going to pull the slack through to the handbrake lever, then cut it and join it back together with the slack removed.
Make sense?
*updated 7/6/11*
Old 1st September 2010, 08:06 PM
David_17's Avatar
Thats the only pic i've got showing the slack coming through (where i'm going to cut and rejoin shorter).
The eagle eyed amongst you will notice i got my diff, driveshafts, drums and rear wheels on today, thanks to the guys at Saturn
*updated 7/6/11*
Old 1st September 2010, 08:21 PM
Enoch Enoch is offline
Looking good, David, quite some progress there.
Enoch
Old 1st September 2010, 08:37 PM
you don't pee about David - before we know it you'll be making brmmm brmmm noises.
Keep it Up......AndyH
Old 1st September 2010, 08:43 PM
David_17's Avatar
haha. Too busy building to make brum brum noises. ...Honest
Thanks for this morning
*updated 7/6/11*
