Old 2nd September 2010, 10:27 AM
Originally Posted by davidimurray View Post
Well I been busy with the wire strippers and stripped out the bits I need of the sierra loom last night.
Now I had always planned to put all the electrics in the engine bay on the scuttle, but now I look at it there seems to be lots of room inside the scuttle under the dash.
So - as per the question where have you put yours?
David,
You can fix the fuse box unit to the bulkhead, easy access, then the main part of the loom will come into the scuttle area where you can mount relays and fix the loom. You can then bring any wiring out along the top of the tranny tunnel. As you say there is loads of room the only additional thing you need to do is to cover the bottom of the scuttle to keep prying hands from reaching into the electrics - keep iva man happy.
Regards....AndyH
