Old 7th September 2010, 09:30 PM
have you got your seat mounts in.
Old 7th September 2010, 09:34 PM
Errrm .... No
That's the first job on my new, to do list
Thank's Rob
Old 7th September 2010, 09:47 PM
Great to hear you have had some time on your build Ronnie
I suggest before you fully fit the side panels to........
make up your tranny tunnel panels & drill the holes in the chassis for when you come to fit them......I,ve had to take my side panels off to make it easier to be able to drill the holes, otherwise I would have been head first in the footwells with legs in the air
Also.....for the same reason....... fully finish the pedal box fitting, makes it alot easier when adjusting the pedals for the first time without the side panels on , in fact if poss, bleed the brake system totally , just makes getting to the M/C a whole lot easier
look forward to your photos.
Old 7th September 2010, 09:56 PM
Front brake pipe brackets ?
Old 7th September 2010, 10:05 PM
Thank's Andy
That is some good advice there .... Whilst I am still feeling a little wonky I am going to make all of the alloy parts first & with my new set of trestles I have a nice easy working height for fabricating all of the sheet stuf
Must admit, I hadnt given a thought to the drilling of the holes for the trany tunnel .... Like you say, that could involve a fair bit of bending over if the sides are fitted
Pleased to see you back on line mate
Old 8th September 2010, 08:47 AM
I,m no "spring chicken" & the thought of me being head first in the footwells drilling holes would no doubt be a task & a half
Another mistake I made.....fitted the seat back panel without cutting holes for the bolt position of the diff hanger , I was being too eager to get the panel into place, DOH, lol. sorted now tho.
Old 8th September 2010, 10:37 AM
Basicaly..
Work out what else has to fit in place and how easy it is to do with other bits in.
My example on the seat rails is that If I put on my ally floor then I would not be able to weld in the seat rails. And they need to be in place to easily cut the trans pannels.
Old 8th September 2010, 10:38 AM
Enoch Enoch is offline
Start from the middle of the car and work your way out. Have you fitted your speedo cable? How about reverse light cablesa nd anything else running down the tunnel? Have you adjusted your pedal stops? What about the seat belt mouts. All of these would be a lot harder to attend to once the panels are on.
Best and all that,
Enoch
Old 8th September 2010, 12:41 PM
Plenty of food for thought there chaps.
It certainly seems like I will be jumping the gun big time if I go & glue those little devils on too soon !!
Definately sounds like permanent fitting of the sides should be done at a much later date .... Too eager, methinks I was just getting a bit ahead of myself
Paul
Timely reminder about the front flexi brackets, completely forgotten about those
Enoch
All good stuff there & makes a great deal of common sense .... Rolling chassis round 2 coming up
Andy
If you have problems getting into those confined spaces, there is no hope for me .... Methinks Carol is going to have to learn to use a drill & spanners
Going to be spending the next couple of days fabricating all of the alloy parts.
I'll then be able to clear the decks & get the chassis rolling once more .... Test drive before Christmas .... I would love to think so !!
Thank's chaps, all of that advice has probably saved me a lot of awkward work.
Promise I will post a few pictures soon.
