Old 9th September 2010, 08:40 PM
Deanno's Avatar
Deanno Deanno is offline
HI Andy, that is all drawn the bit i'm after is the cut out for the tunnel (I could'nt think of the name earlier) i've got the width but not the height.
Old 9th September 2010, 08:50 PM
My apologies,
The height of the tranny tunnel side panel, if thats what you need is 302mm at the rear ( thats fitted upto the seat back panel end) & the gear stick end is 345mm on drivers side & 352mm on passenger side.................
OR
If you look at the diagram on page 45 , lower sketch it shows the height from the base of the bottom chassis rail to the top of the tranny tunnel rail TT7 as 305mm perpendicular height.
hope this helps
Old 9th September 2010, 09:04 PM
Deanno's Avatar
Cheers Andy
