Old 12th September 2010, 01:38 PM
Jimmyd Jimmyd is offline
Default IVA and side panel holes
I'm I correct in thinking the holes in the side panels for wishbones, exhaust etc do not need a radius if the 100mm sphere can't come in contact with the edge of the hole? It obiviously then does if the sphere can reach it.
J
Old 12th September 2010, 02:47 PM
J
That's correct.
Old 12th September 2010, 07:37 PM
Some edge trim would probably keep them happy.
Old 12th September 2010, 08:42 PM
That's true, and it would look neater too, but if they can't touch them with the sphere, then they can't fail you on them.
It's worthwhile anyone facing an IVA test making a sphere, I made one with a half a 'diablo' plastic toy which happened to be almost exactly 100mm.
Old 13th September 2010, 05:26 PM
snapper snapper is offline
Basically edge trim everything you can get edgetrim on.
No one fails for to much edgetrim
Old 13th September 2010, 06:03 PM
And no one fails when a non contactable edge has no trim. There's no harm on edging non-contactable edges, and might make it look better too, but it's not actually an IVA necessity.
