![]() Get hold of the best mig you can. You want around 150A and to be fan cooled.
MMA or stick welding is not easy for 1.5mm thick steel. You can teach yourself with some offcuts and some practise. There are plenty on here and lcb that will give you pointers if you post the pics and some may even give you an hour or so of ther time and show you.
Nowt again. |
![]() Quote:
Only reason really I'd go Stick is that my Granddad is willing to teach me, and what with his experience I'd really gain from it - he was a Royal Engineer, then set up his own large fabrication business, so definitely one to learn from! Though I've not actually asked yet if he could teach me MIG, so I may have to chat with him this weekend... Apologies if posting links is frowned upon, I have no affiliations - but is this a recommended/suitable choice? This |
![]() I cut and welded my chassis using a a metal cutting bandsaw and mig. I'd never used a mig before, but having talked to welder friends I was convinced that it wasn't too difficult to learn. I bought a 150A fan cooled machine and sat down one weekend with a pile of 1" box off cuts and by the end I'd cracked it. The one thing I found that helped more than anything else was an auto darken visor, it was worth every penny. The metal cutting band saw was from a previous project and made the cutting of the parts a doddle. Accurate angles and lengths made the assembly and tacking fairly straightforward. The finish welding caused a few backtracks but the finished chassis came out to the mm thanks to the excellent cutting list in the book.
![]() Quote:
![]() But practice should help! And naturally I'm not gonna take on the task without being sure I'm good enough. I used an autodarken mask, and a regular one (as well as one of them old style hand held ones (!)) and definitely loved the autodarken! |
![]() sounds like your starting from a better level than I was at, go for it, it's part of the fun!
![]() ive been a welder for the past 20 years
im welding my chassis 25x25 shs 1.6 thickness, using a 170 amp single phase mig, gas im running will be carbon dioxide, ( use plenty of anti splatter spray ). For all my front and rear end suspension parts, ill use mig to tack them up but over here in New Zealand all final welding of suspension parts MUST be tig welded up then crack tested. Also we arent allow to weld the steering shaft MUST be splined and pinched bolted to the universals. hope this helps |
![]() Quote:
Out of interest, would you reckon that Tig produces a better weld, if suspension has to be Tig? |
