Old 19th September 2010, 09:57 PM
Originally Posted by Deanno View Post
ant the lights will be the same as the Escort's regarding the fog light.
If your donor loom is setup so that the rear fog light can be activated when only on "side lights" ( as older cars may have done ) then it will fail the IVA requirement,
As Mr H has said, the rear fog light must only be operable when using "Dip or Main " headlights, its a new requirement on the new IVA ( older SVA test would have allowed it ).
