Old 20th September 2010, 07:50 PM
rapidtornado's Avatar
Default Part ID required please
Hi
Whilst modifying my manifold I managed to snap off what lloks like a plastic valve of some kind on the EFI inlet manifold.
Can anyone identify the correct description for this part (in the pic attached) and where I could get a replacement? It looks as if it maybe just a press/retian fit in the housing
Thanks
Matt
Old 20th September 2010, 08:31 PM
Could be the vacuum take off for the brake servo ,not needed if it is.
Old 20th September 2010, 08:32 PM
David_17's Avatar
David_17 David_17 is offline
That was my first impression too.
*updated 7/6/11*
Old 20th September 2010, 08:39 PM
Enoch Enoch is offline
Yes, it's a blanking plug. Don't think it was for the servo, my car was fitted with a servo but it had one of those blanking plugs too. Think it may have been some sort of test port? You don't need it anyways.
Old 20th September 2010, 09:18 PM
Thanks gents, so with a blank hole there at the moment and no thread to screw a blanking plug into what do you recommend as it just a 7mm hole at the moment....?!?!
Old 20th September 2010, 10:26 PM
les g les g is offline
tap it to m8
a bit of loctite or thread sealant and it shouldn,t leak air or fall out
i know the purists will be along in a minute and say you need a 6.8mm
hole for m8 but but if you have a tight 7mm hole i,d have a go at that
after all you are just blanking a hole
if you are really keen go the next size up and drill and tap m10 with a fine pitch etc
but i know what i would try first
les g
