Old 20th September 2010, 08:55 PM
Deanno's Avatar
Deanno Deanno is offline
was the idler put on sing a bracket?
so when i link it up to the tupe 9 i need a sierra starter?
do you have any dimensions for the braket you made to take pulley/ idler?
Old 20th September 2010, 09:00 PM
Coozer's Avatar
Coozer Coozer is offline
I made the idler just postion it so the belt got good contact round the other pulleys. You can put it anywhere really. If you look closely you can see the mole grips holding the belt? This was to get the length then down off to Halfords for the correct belt.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 20th September 2010, 09:02 PM
Coozer's Avatar
Theres a few pics here:
http://picasaweb.google.com/Coozer18...bz_ei8r9bp3gE#
I have plenty more elsewhere if you need anything else.
Old 20th September 2010, 09:03 PM
Deanno's Avatar
thanks for all your help.
no doubt you'll be hearing from me in the future.
Old 20th September 2010, 10:49 PM
Coozer's Avatar
Old 21st September 2010, 09:52 AM
David_17's Avatar
David_17 David_17 is offline
My sump looks just like your above pic steve, so should fit. Cheers
*updated 7/6/11*
Old 21st September 2010, 07:09 PM
David_17's Avatar
Here's my idler set up. Incase anyone reading this needs some inspiration. I just used some left over box section bolted to the oringinal engine mounting studs - Much easier than making a bracket that bolts onto the side of the block.
*updated 7/6/11*
