![]() tap it to m8
a bit of loctite or thread sealant and it shouldn,t leak air or fall out i know the purists will be along in a minute and say you need a 6.8mm hole for m8 but but if you have a tight 7mm hole i,d have a go at that after all you are just blanking a hole if you are really keen go the next size up and drill and tap m10 with a fine pitch etc but i know what i would try first cheers les g |
