Old 21st September 2010, 07:15 PM
shh120m's Avatar
shh120m shh120m is offline
Went to machine mart, bought impact gun, no joy. Put a bar accross the studs and got all three neighbours to stand on the subframe while i forced on a 12ft piece of scaffolding pipe attached to the wrench and all i did was lift everyone off the ground. I really dont know what to try next.
David, you said that i dont need to remove the hub nuts? dont i need to remove the hub to get the driveshafts into the rear hub carriers? Either way i would like to remove them just to put new bearings in.
Does anyone have any further suggestions? im getting pretty tempted to start the grinder up or try and find an industrial nut splitter.....
nathan
Old 21st September 2010, 07:19 PM
David_17's Avatar
David_17 David_17 is offline
The hub carriers have 4 bolts that come out with the driveshafts (as you'll know lol). The full driveshaft can be slid through the back plate of the drum then into the diff, then the 4 bolts just tighten onto the roadster's uprights.
Once they're on the car, the hub nuts will be much easier to loosen.
*updated 7/6/11*
Old 21st September 2010, 07:37 PM
Coozer's Avatar
Coozer Coozer is offline
Do what I said. When u stand on the length all the torque goes to the nut.
I've used that disc with the box welded on with stub shafts not attached to anything, drive shafts, the car etc.
It works correctly!
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 21st September 2010, 08:05 PM
shh120m's Avatar
only problem is i have drums, do you think it would be posible to do it by bolting the box section onto the wheel studs? im not bothered about them bending or snapping cos thier relatively easiy to get out.
Old 21st September 2010, 08:11 PM
does not matter that they are drums just put the disk on like a wheel.
Old 21st September 2010, 08:13 PM
Coozer's Avatar
Want me to come down and help ya?
Cheers,
Old 21st September 2010, 08:18 PM
shh120m's Avatar
DONE IT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
phew, thanks for the help guys and the kind offer. I was beginning to have a nervous breakdown, dont ever want to have to do that again! that was some serious torque, iv bent a piece of scaffold bar getting those blighters off!
nathan
