Dont want to pee on the bonfire,before you weld the mounting plate for the hub to the rear upright it will pay you to check the caliper does not hit the upright and the handbrake will work.
It needs to be at about 2 o'clock position,I think you may find the answer in Spikehaus's blog as he has sorted it.
many thanks |
Hi Misty,
Paul is correct just make sure you get the RU8 and 7's handed right, the side with the 2 bolts 94mm apart, not 90mm, need to be at the front facing forward 30 to 40 deg. All the Best....AndyH
