Old 28th September 2010, 10:40 PM
I prefer the one available from Machine Mart as it allows the steel rule guide to sit ontop of the steel box section (as it is stepped) and so ensures the guide is set at the angle using the steel to be cut as the horizontal plain.
A little more expensive but very robust & accurate.
Old 29th September 2010, 05:19 AM
Coozer's Avatar
Coozer Coozer is offline
One of these any good? Nice and robust and cheap..
http://www.toolstation.com/shop/Hand...0/sd150/p84416
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 29th September 2010, 11:40 AM
I have got one of these cant fault it perfect angle every time to 0.00 deg
http://www.axminster.co.uk/axminster...er-prod783404/
My Pictures
Old 29th September 2010, 06:16 PM
Locky Locky is offline
Thanks all, i may go for the one talonmotorsport mentioned. cheap and looks decent quality. i wont be using it for much else.
Cheers.
If it has breasts or wheels it will give you problems.
Planning Stage
