![]() Hi chaps
As it happens, I have just installed my rear drive train. I am using standard drum brakes, 7" diff & push in shafts. Tis very difficult to measure with any degree of huge accuracy but for what it is worth, here is the best I can measure. From drum outer face to drum outer face, I get something in the region of 1530mm ( 1529mm to be exact ) As said, it is an approximate measurement due the back of the build being on stands & the hubs are not set dead upright ( took a mean average measurement though ) I believe the measurement to be accurate enough to give you some idea if you are in the same ball park ![]()
