Old 1st October 2010, 09:59 AM
old_bill old_bill is offline
Originally Posted by Enoch View Post
Just wondering if anybody has made their scuttle to the book plans.? I am going to make a steel one but looking at the steering column the book design would have to be changed as there is no way a bit of 1 inch square would fit between the column and TR9. Anybody done this? Am I going mad? Just want a quick sanity check before going any further.
Enoch
Did you find a solution to this problem? I'm thinking of fabricating the scuttle myself.
Thanks
Bill
http://www.flickr.com/photos/old_bill/
Old 1st October 2010, 01:29 PM
Enoch Enoch is offline
I did fabricate it in the end, it actually ended up very satisfying. If you look at my build diary there are some photos in there - www.deepfolly.co.uk
It was quite tricky to get the two hoops of 3mm x 25mm steel to form properly - because the front of the scuttle is smaller than the back the rear hoop has to kind of angle inwards and downwards so the skin goes on properly. It took a fair bit of messing about but then I have never done anything like it before so if you know what you are doing you will find it easier than I did.
Hope that helps,
Enoch
Old 2nd October 2010, 01:01 PM
Thumbs up
Thanks Dave. I have been following your blog and have found it informative and at times entertaining It was your blog that gave me the idea of doing it myself.
Can you give me some hieght dimensions? there are none in the book, and as you say there is a hieght difference from the back to the front of the scuttle.
Any help appreciated
Bill
Old 2nd October 2010, 01:33 PM
old_bill, you can find the basic proportions of the Saturn GRP scuttle here:
http://www.haynes.co.uk/forums/showt...?t=3578&page=5
Personally, I would make the scuttle continue the lines of the bonnet, so the rear would be about 1 cm higher than the front, something along these lines:
Old 3rd October 2010, 10:08 AM
Hi Bill, it's more or less like Alga's diagram except I made mine slightly higher because of the height of my DOHC engine. The rest of the dimensions / angles were kept the same, my one was about 20mm higher than "standard"
Enoch
Old 4th October 2010, 09:09 AM
3GE Components's Avatar
Try dropping Mark Allanson a PM, Trophy Blue on here, he made his scuttle and I'm sure he has a PDF to show how he did it.
Kind regards
John
