Old 9th October 2010, 06:00 PM
Originally Posted by misty View Post
Hellooooooo
can someone tell me if it is ok to use a ford escort mk 3 manual rack instead of a mk2
or
is it possible to use a mk1 rack instead of a mk 2 as in the book
I very much doubt it, the Mk3 was front wheel drive, and bound to have different geometry
Old 9th October 2010, 06:24 PM
Enoch Enoch is offline
The mk1 and 2's are the same except they have different threads on the rod ends. From memory the MK2 is 12mm and the Mk 1 is 1/2 UNF. It's no big deal if you are making the track rod extensions yourself, I have a MK1 rack and just drilled and tapped the holes in my extension pieces to suit.
Enoch
Looking at the manual for the Escort Mk4/5 & 6
The steering arm is at the rear of the hub assembly if this should prove to be the case with the Mk3, you'll end up with clown steering.
The mk2 escort rack is designed to opperate the steering via front of hub arms. ( Same as the Sierra )
Old 9th October 2010, 06:32 PM
misty misty is offline
AHHHHHHHHHHHHHHHHH
that solves my problem
i will keep hunting for a mk2
many thanks to all
Old 9th October 2010, 07:29 PM
why hunt you can get a brand new one from rally design for £56.
My Pictures
