Old 18th October 2010, 08:53 PM
Originally Posted by carlknight1982 View Post
is that 120mm from the center of the bolt mount hole or is that 120mm for just the "shaft" not the round bit with the bolt mount in.
I used 120mm from the center of the hole to the edge of the chassis just above the upper shock mounting bracket,mount the stalk on the side of the chassis rail as this way you don,t need to cut the nose cone , this then should give 90cm between the holes of both brackets.
Old 18th October 2010, 09:02 PM
carlknight1982's Avatar
Andy as always I could kiss ya!
Roadster No 2 build
Cost to Date : £93
Old 18th October 2010, 09:06 PM
runs screaming
Old 18th October 2010, 11:10 PM
Good job he is a few miles Andy !!!!
