Old 19th October 2010, 08:27 PM
rhysadams rhysadams is offline
Originally Posted by Andy_B View Post
Evening...Started stripping my granada today ...reining myself in to rip it to bits without labelling everything...and photographing...the granada loom is huge ...electric everything....SO my first question is how do you vent the aircon system in a safe sort of way..and do you usually leave the aircon pump on the engine so the belt pattern is the same...2ND question if i undo the prop shaft bolts is it an easy lift out with engine with fron x member removed ??
hi im basing my roadster on the bmw e30 so not to sure about the air con unit sorry but im sure its very similar with taking the engine out i ubolted the prop from the diff and took the fron x member off and it came out quite easily and best of luck with you build
rhys
