Old 31st October 2010, 02:39 PM
If the engine rotates the wrong way can you not just turn the diff upside down?
Old 31st October 2010, 04:01 PM
depends if the diff has a breather on top ? in theory it could
looks like no need tho honda are spinning this one the other way but every other honda engine span the other way
was pointing out it would need considering as most people presume engines all spin the same way
Old 31st October 2010, 07:58 PM
chrisunwin chrisunwin is offline
Longerr
Hi, if you get the S200 motor, make sure you get the ECU AND the correct key for it, they are coded, and without the key, you wont get the ECU to work. There are aftermarket ECU's, but that is more cost.
On the plus side, the S2000 motor is just about unbustable, they really sing. I know, as the wife bought me one for my anniversary.
Regards
Chris
Old 31st October 2010, 08:08 PM
Originally Posted by monsterob View Post
if you get the s2000 engine will you be using the s2000 rear diff ?
honda engines rotate the opposite way so if you used a sierra diff you,d go really really fast just backwards !!!
The S2000 engine, F20C, rotates clockwise, contrary to the rest of the Honda engines.
Old 31st October 2010, 09:37 PM
i did look and corrected myself seems honda have had "a change of direction !!!"
waaa waa waaaaaaa !
Old 1st November 2010, 04:07 PM
Just for the S2000. It's their only longitudinal, RWD application.
Old 4th November 2010, 12:40 PM
Longerr Longerr is offline
In my search for a Duratec kit I have found this Kit Car, can anyone tell me what it is, or where can I find more info about it?
http://www.atpower.co.uk/#/throttle-bodies/4541265491
Old 4th November 2010, 12:44 PM
mark mark is offline
I think it may be an MK midi
Stick it in google and im sure plenty of info will come up
Old 4th November 2010, 06:38 PM
Thanks Mark.
From what I have found untill now for my planned Duratec tunning was this kit, 203BHP, even without cams, for £1933, but it's still quite a lot of money, anybody know about something cheaper, about 180BHP would be enough
http://www.sbdev.co.uk/Duratec/Durat...ttle%20kit.htm
Old 4th November 2010, 06:44 PM
Coozer's Avatar
Coozer Coozer is offline
It's a Sylva Riot.
http://www.sylva.co.uk/riotSE.html
AT had a stand at Stoneleigh and I nearly blew the budget on a set of them TB's for my zetec. Good job I'd already broke the bank on an Omex before I saw them!
LG,
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
