Old 7th November 2010, 03:54 PM
Yep, good progress..
And I will be on for Blast #2 in a few weeks
Old 7th November 2010, 07:21 PM
shh120m's Avatar
shh120m shh120m is offline
iv drilled a 4mm hole to pass the cable through the top rail into the headlamp brackets. i was just going to cut them midway and remove a section of the oval tube then reweld rather than tryng to cut near the chassis( knowing my luck id cut through the top rail!). If i do this will they cause clearance isues later on?
thanks
nathan
Old 7th November 2010, 07:28 PM
mark mark is offline
Just cut them very near the top rail if you are worried about cutting into it then dress it back flush with a flap disc
Shorten them and weld them back on, it will save mucking about trying to cut them in the middle, shorten them and weld them back together again neatly.
Old 7th November 2010, 08:49 PM
I thought the brackets looked too long too, but assumed I must have done it wrong..
Phew!
