Old 12th November 2010, 07:47 PM
Default Front lower wishbone question
Hi all just a quick question, had seamless tube delivered 19mm & 25mm erw 16s.w.g. as per the book. The drawing for the 5mm plate shows a 3mm where the tube fits over but this is decidedly bigger than the wall thickness of the tube has anyone else had this problem ??????????
Old 16th November 2010, 06:50 PM
squbti's Avatar
squbti squbti is offline
well i´m not sure i understand correctly but i have been looking at the drawings & i think that 25x2mm is what you need & not 25x3mm , the iner diameter of the 25x2 is 21mm so to fitt a plate into the tube it would have to be papper thin but the tabs on the plate in the drawing are 5mm thick & therefor must be a little smaller to fitt. i wish i could make a drawing it wuold make it alot easyer to explane but hope this makes sence.
samy
