Old 12th November 2010, 08:48 PM
Forgive me Baz, but I don,t understand this bit of what you intend to do
The only point I would make is that if you ditch the D13,s & increase the capacity of the tank along the rear GRP1 tube then that would create alot of unsupported weight with a full tank, or maybe i,m not understanding your suggestion of the rear layout?
The tank on my car is only approx 10mm away from the GRP tub.
andy im using the grp tubes to hold the tank not the grp tub not cp8 then not fitting d13 that get in the way of the tank then tieing in the ends of grp1 to the two tubes that come down dignaly from the rear shock mounts.
plus tieing in two supports down off the roll bar to the top of the rear top rail of the back end (linked to the bottom rail)
most likely not going for a grp back end but could be done i think
ps run out of tubes now all fitted a dream
