Old 14th November 2010, 08:36 PM
Wynand's Avatar
Wynand Wynand is offline
Thanks Andy,
The steering rack arms do look a bit odd, but that is the position I achieved zero bump. Moving it forward - and it can only go about 30mm then against the frame front upright - induces toe out when bumped.
I thought of modifying the steering rack bracket to move forward or backwards and will perhaps do it just in case...
The chassis is only primer coated after blasting since I still have to fit engine mountings, the gearbox tunnel (done) etc before epoxy coating the frame for final assembly.
Wynand
http://5psi.net
