Old 25th November 2010, 06:52 PM
You can use a plumber pipe bender if you get stuck, but it is hard work and will flatten the pipe a bit in the 22mm side. You will get the correct radius though, try some heat to soften the tube and take it slowly.
Try some local fab shop they may have some pipe benders you could have the use of for biscuit fund.
Andrew
