Old 12th December 2010, 07:47 PM
Deanno's Avatar
Deanno Deanno is offline
Default Wishbone Tube
In the book iy says to use seamless tube i am aware that its slightly stronger. but could they be made out of rolled or drawn tube?
Any Input would be greatly appreciated.
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 12th December 2010, 08:05 PM
fabbyglass
yep they can I wouldn't bother using cds for 'bones and you wil lfind nearly all kit car firms don't use it either.
I used to make wishbones for single seater race cars using 18swg erw tube, scary thin wall but the 'bones are designed to go rather than the chassis.
Old 12th December 2010, 08:06 PM
You could use ERW for the wishbones there's nothing stoping you. For the front lower turn the seam round so that it faces the 5mm plate. It only says use CDS as it would seem safer to do so. If you smack the wheel against a curb your more likly to pull the bolt through the suspension bracket, rip the bracket off the 1.6-2mm chassis or bend the wishbone than split the wishbone tubing. As for CDS being stronger it's only stronger in that it's ment to be used for hydrualic lines and hyd. rams for internal pressure as there is no seam to split. There are two main types of CDS in the 19mm - 3/4" and 1" - 25mm sizes hyd and mech. Hyd. grade and is softer the mech. grade ,you could end up with material that could be weaker than ERW. At the end of the day you pays your money you make your choices.
Old 12th December 2010, 08:31 PM
davidimurray's Avatar
If you do plan on using ERW bare in mind that there is a 'joint factor' you should use when doing calculations which is around 0.85-0.95 that of CDS.
