  #18
Old 29th December 2010, 09:30 PM
ahh theres the spanner in the works , the omega uses a drum setup within the rear disc but i found that after the hubs were made id not left enough room to get the shoes and the mechanism in. i was planning to use the mechanical spot calipers for the handbrake only. and the rear caliper from the omega also. i thought the spot calipers would be siutable as the alfa 147 i have uses a similar system for its handbrake just with one caliper both cable operated and hydraulically. more thought needed there then ........
