Old 1st January 2011, 09:26 PM
rapidtornado's Avatar
Default Crush tube length
All pretty sure on this but just checking crush tube length is 35mm? didn't know if it should sit marginally proud or recessed.
Sorry for the DAQ
Rapid
Old 1st January 2011, 10:06 PM
Just to be clear the crush tube is the part that goes inside the polybushes, has the bolt pass through it and gets clamped by the suspension bracket. This part should be stainless steel and 44mm long. The 33.7 OD bush tube that the poluybushes go in are 35mm long.
Old 1st January 2011, 10:11 PM
Thanks for clarifying, much appreciated!
Rapid
