Old 14th January 2011, 02:30 PM
mikemph mikemph is offline
I do have a can some where but never used the stuff, does it work?
http://m1kemph.wordpress.com<---- build blog clicky
Check us out on facebook. Hamlet Engineering Services limited
Old 14th January 2011, 02:52 PM
fabbyglass
No not really as the heat burns it off first...!!! Much better to use an old file and knock the spatter off yourself as it then lets check to see if you have missed any welds.
Old 14th January 2011, 06:57 PM
shh120m's Avatar
shh120m shh120m is offline
i find it helps on stuff thats say, next to the item thats being welded for eg when your adding something to the chassis and its getting splattered, just a quick misting normally helps
Old 15th January 2011, 10:41 AM
yes thats how it's intended to work, reducing the chances of splatter sticking to fresh ground steel or shiney new ERW.
