Old 28th January 2011, 07:48 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, mine all went together fine without removing abs rings or anything else.
makesure the hub is pulled all the way through the bearings you should see a couple of threads sticking through the nut. also make sure the shafts havent popped out of the joints and check the prop flange on the diff is central in the tunnel.
finally when its all together you should be able to move the shafts a little sideways this will show nothings binding
hope this helps
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
