Old 5th January 2011, 10:32 PM
Coozer's Avatar
Coozer Coozer is offline
Originally Posted by adrianreeve View Post
Jas
Just use two 4 or 6 way fuse boxes to distribute the leccy. Feed one from the battery, the other from the ignition switch.
Adrian
Nissan Note has a distribution link hanging off the battery. Its has a starter cable connection, 1x60amp and 3x80 amp with big spade connections on the bottom.
get down the scrappy and that will help with distribution off the battery.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 27th January 2011, 06:48 PM
jasongray5's Avatar
Big thanks to everyone with their help thus far on my wiring?
Ive got everything in and working, I have tried to wrap it in loom tape, and secure it where it will allow, its less than the 300mm anywho!
Heres a pic, do you think this will be ok, all loose wires are either for the dash, to be tidied after the dash is fitted, or for the repeaters in the scuttle, so will also be tidied later
Cheers fella's
Old 28th January 2011, 08:45 PM
Old Git Old Git is offline
Looks OK to me chap
I'm busy building my own loom from scratch too on my McSorley +442 (stretched Ron Champion Locost). Got the dash wired to a couple of connectors so it can be easily removed. Got to set to now and fit the rest of the wiring to the chassis. I spent about 4 days designing the wiring diagram. Thought it would be better to work from a diagram rather than wire 'on-the-hoof' and then try and draw a wiring diagram from that.
JB
Old 29th January 2011, 11:20 AM
jasongray5's Avatar
Cheers for the reply Old Git! I have made a diagram mapping exactly what each wire does, Just so if I ever come to sell the car, if something electrical goes wrong, whoever buys it will have an idea of what does what!
Someone on here published a good wiring diagram too!
Cheers again
Old 29th January 2011, 01:58 PM
TSM Locost's Avatar
Default Wiring Diagram.
Davidmurry did the excellent Diagram
http://rapidshare.com/files/41145061..._Wiring_V1.xls
Be Lucky, Mike.
