Old 3rd February 2011, 05:52 PM
Originally Posted by jasongray5 View Post
I have 2 different versions? Neither fits?
I think I need one from a facelift mk2 Sierra, as the column came from a G reg 2.0 DOHC
I only need the top half? And would trade one of the other shrouds, or beer tokens, or a MT75 Gearbox?
Any one got one? Or any other Ideas on making the other ones fit?
Cheers again, Jas
Take a pic of what you have...
Old 3rd February 2011, 07:07 PM
Wink Just a thought mate
Are you sure that you are not missing the little upper shroud mounting clip ( Just above the hazzard warning switch !!??
The shroud I sent home with you should fit.
That was one removed from a 91 2 litre Twin cam jobby
As TT said, try & get a picture up
Old 3rd February 2011, 07:46 PM
jasongray5's Avatar
Yeah Ron I have that one of yours, and another I got out of a P100, they are the same, and then mine is different again? I have the little thingy, but it wont physically fit over the shaft?
Mine is the one on the Right
Old 3rd February 2011, 07:55 PM
Ask at the chemist for XL.
Old 3rd February 2011, 07:57 PM
the one on the right is a stock MK2 none adjustable lower half.
Front left looks like a MK2 adjustable lower half
Rear left looks like a MK2 top and bottom.
What column do you have.
Old 3rd February 2011, 08:02 PM
fabbyglass
This part of a seven nearly always looks crap as the shroud doesn't meet up with the dash, a single tube with a steering wheel on the end of it with switches elsewhere looks far better
Old 3rd February 2011, 08:03 PM
Bit of a mystery there Jas
Wish I was close enough to pop in & have a gander
I have no idea how many different types of column & shroud were used on the sierra !!
I'll keep an eye in the breakers mate, you never know, I might come across another complete Sierra steering assembly
Old 3rd February 2011, 08:11 PM
jasongray5's Avatar
Quality!!
My donor came with the non adjustable shroud, so im guessing non adjustable?
Old 3rd February 2011, 08:14 PM
jasongray5's Avatar
Yeah it wouldnt be so bad if one of the other covers fitted it, but they dont, so hey ho. I do have the column out of the p100, but there is no key to get the barrel out of the ignition, and I really need the steering lock for IVA.
Fabby, didnt someone make their own shroud using a plastic sweet jar? Im sure it was Dogwood said he had?
Old 3rd February 2011, 10:25 PM
Jas
I changed a Sierra lock the other day without the key
Twated the little detent pin in with a pin punch. Prised the lock out of the housing slowly, slowly .... Once it was part way out, I was able to turn the lock assembly to the no 1 position & pull the rest out with ease
New lock just popped straight in as it should , jobs a good un
