Old 7th February 2011, 03:30 PM
Cool Welcome to the forum Darren
No real reason as to why you can't fit the fuel tank above the diff cage.
Personaly my view is, in the event of a heavy rear shunt, the tank will probaly not prove to be much safer up there
To be perfectly honest, a kit car of any sorts is not the best thing to have a shunt in
Just adds to the thrill of driving
Old 7th February 2011, 03:45 PM
dooner02 dooner02 is offline
Default cheers bonzo
you are probably right. for performance, low down is obviously better and leaves more access for handbrake and diff.
maybe i could invent an ejector seat instead.
cheers, darren
Old 7th February 2011, 05:44 PM
fabbyglass
Might have dreamt this but Im sure there is a car by Sylva with it's tank in the middle of the car.......
Old 7th February 2011, 07:18 PM
I have mounted my tank above the dif, and its fits perfectly allowing the swirl pot to pop out on the underside.
Old 7th February 2011, 08:52 PM
mark the tank on the riot is in the passenger footwell. from what i have seen if a tintop hits the rear of a 7 it wont matter where the tank is.
25-30kg of fuel mounted high up in a 7 can play havoc with the handling. i tried my tank above the diff as an experiment looking for ways to increase capacity, with it full up the car felt quite nervous on the back end through the fast b roads so i put it back in the correct spot
My Pictures
Old 8th February 2011, 07:33 PM
fabbyglass
Cheers Ash, Thought I dreamt it...... Did your mate get his Riot built by the way?
Old 8th February 2011, 09:27 PM
nope 2 years on and its still sitting in his garage. although he has built a new garage in that time as well as an extension. i offered to build it for him but he wants to do it himself which makes sense after building a new garage to do it in. instead im now building an mev exocet and i must say it is the most simple thing i have ever had the pleasure to build. its not what i would call a typically pretty car but the thing sticks to the road like a crazy sticky thing and after selling off all the unwanted mx5 bits will owe me next to nothing. plus im using the mazda 1800 meaning it will go like a scalded cat
My Pictures
Old 9th February 2011, 10:21 AM
axle's Avatar
axle axle is offline
Yes I go along with Ash here, the tank should be in the position as per book.
In case of any shunt you shall have less chance of getting soaked by the petrol.
Regards Axle
Old 10th February 2011, 12:28 AM
Cheers lads, all food for thought. passenger foot well sounds interesting.
