			 Gents
	Anybody got a UJ joint off a maunal Sierra steering rack I could buy off you? Only found out this weekend that the Sierra PAS rack has a different diameter splined shaft to that on the manual sierra rack (which is the same as the MK 2 escort rack) PM me if you can help Cheers Rapid  |
			 do you mean the bit with the rubber disc that clamps direct to the rack input shaft i think i might have a spare one somewhere
			 I guess so, there is no rubber clamp bit on the one I have but yes, it's the sections that clamps onto the input splined shaft on the rack and triangle shaft/clamp on the other end of the knuckle
	cheers  |
			 i will have to have rumige in the garage when im in there next
